High tunnel
Animal
I went and got it today, this looks like a project, but what the hay. This is going to be fun.
unheated plastic covered greenhouse. Ours work great at protection from cold. W use frost covers on the tender produce when it gets real cold in the tunnel houses.
I think I am really going to enjoy it when I get it up and going. I know their is a lot to learn, but when you stop learning you are dead as far as I am concerned.
Your on target on the learning. Did your tunnel come with Z track to hold the plastic. Cost little more but sure makes it easy to hold down the cover. Last tunnel I put frame up by myself and had the kids help put the covering on. Tied tennis balls on one edge of covering with rope over ridge and just pulled cover over. Pick a warm non windy day so you can pull the cover tighter. We have ours were you can roll up sides when warm out. Works good and no electric for fans needed.Good luck.
Oh ya Dusty, I got it all, my daddy told me when I was young, if you are going to fight a bear, fight a grizzley! 30X72 with roll up sides 8' walls and double doors. I know this is going to take a ton of work to make it successful so I want to start and use the best. Any advice you could give me would be greatly appreciated..
