Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: converting corn field to hay
rrlund
03-05-2014 07:23:45
You won't get 10 feet if you go in with the field cultivator first. If you aren't going to moldboard plow it,then I'd say yes,use the brush hog first. Then you'll have to disc it a few times to cut the stalks up even finer,then MAYBE you can get the field cultivator through it.
Maryland Hay Farmer
03-05-2014 07:33:08
 Re: converting corn field to hay in reply to rrlund, 03-05-2014 07:23:45
I have a 3 moleboard plow with 14 in. blades, but my tractor can only pull it if its no more than 6 inches in the ground.
Larry NEIL
03-05-2014 07:49:09
 Re: converting corn field to hay in reply to Maryland Hay Farmer, 03-05-2014 07:33:08
Just it will make a fine seed bed. disc at an angle to better cut up the stalks. Disc it a 2-3 times and if you can put a harrow on your disc and pull it the 2nd or third pass even better.
Kornfused
03-08-2014 05:41:52
 Re: converting corn field to hay in reply to Larry NEIL, 03-05-2014 07:49:09
Larry has it, although I did not have the option of a harrow so I used a drag. - I ran my disc through it 3 times - 3 different directions and then planted with a brillion planter - result was a very nice pasture.
Copyright © 1997-2015 Yesterday's Tractor Co.
