TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: Homemade vertical tillage tool
James22
01-22-2014 12:41:36
Assume you intend to straighten the disk gangs which means you would need to change the disks which currently have too much "dish" to work properly with a reduced disk gange angle. Otherwise you aren't really going vertical till. True vertical till requires quite a bit of implement weight to get penetration if the soil is dry. If wet no problem, but one shouldn't be out there when it is wet. I converted a JD 335 disk which at that time was the heaviest tandem they made. Wouldn't want anything lighter and it is significantly heavier than what you have. Not really vertical till but if your intention is to mount a row or two of chisels between the disk gang, it would accomplish in one pass what the two implements do separately. If you have the time, money and inclination it would be an interesting project.
