TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: Homemade vertical tillage tool
JMS/.MN
01-22-2014 08:06:24
Chisels always run deeper than discs. Half to again as deep, if they"re going to do a decent job. I doubt your combo will accomplish as much as the factory vert tillage tools. Make a pass with each machine and see what the results are...you can do that without cutting up anything.....If you want to rip hardpan, you need ripper shanks.....longer than chisel shanks. And lots more power.
VicS
01-25-2014 19:23:40
 Re: Homemade vertical tillage tool in reply to JMS/.MN, 01-22-2014 08:06:24
Neighbor to the north made one from a heavy 9 inch spacing JD disk. One of those that just have one wing. about 21 ft wide. He straightened the gangs and made sure the back gangs split the front ones. Then put 2 inch no-till wavy coulters. Also has 2000 lb or so of weight in the middle of it. Pulls it with a big CIH Magnum front wheel assist. Says need to stay above 8 mph and 10 is better. He runs it down on the spools, so is going 6 to 7 inches deep. Has rolling baskets behind. Seems to do a good job. But I'm not sure yields are better than just no-tilling. He says lets him plant a couple of days sooner.
