To Bushhog or Not
Anonymous-0
Sprayed a field with Grazon,Remedy mix , July 6th. Got good kill on everything but some oak. They are turning but not dead. Should I mow them or not?
10 acre with boomless nozzle. rained 6" just before sprayed,Quart of grazon, pint of remendy.14 gallon water an acre.
I have sprayed many acres with the mix you used and doubt you will kill the sprouts unless you treat individually with a wand. That being said, if you mow as low as possible now they are weakened you probably will do some good on oak; not hickory, hedge, or locust. If you treat individually, you might think about using dicamba for oak.
