Yesterday's Tractor Co.
Shop Now View Cart
Using Your Tractor & Crop Talk
Discussion Board - Re: Deutz Fahr KH40 Tedder
07-06-2013 13:50:23
If it is the same as my Fahr KH40 Centipede (2 speed). They are a nice tedder for the age. I think I have a book, if I do I can scan and send you a copy.. Most all the roll pins are metric and from what I've found anything not common is very difficult to find....
07-06-2013 16:18:38
 Re: Deutz Fahr KH40 Tedder in reply to Sako, 07-06-2013 13:50:23
Thanks this one is the centipede as well, how does the two speed in it work I haven't come across that yet. It would be great if you could send a copy of the manual, I would really appreciate it. I had a question on the main gear box, it looks like this one has been completely packed with grease, is this correct? Or should it have gear oil in it? Thanks very much
07-12-2013 18:58:07
 Re: Deutz Fahr KH40 Tedder in reply to AdamOH, 07-06-2013 16:18:38
Sorry it's taken so long to get back to you. I haven't been able to find a manual (thought I had one, will keep looking). Mine has gear oil in the main gear box, only the stars have grease. The two speed works just by swapping the pto shaft to the other stub shaft, from what I was told it slows the basket speed by half for more delicate crops (I never needed to use it). As of this afternoon mine is out of commission, my LH outer basket drive shaft sheared where the drive pin is... A lot of money later I just got done uncrating and assembling a new Stirex...
07-13-2013 04:58:05
 Re: Deutz Fahr KH40 Tedder in reply to Sako, 07-12-2013 18:58:07
Thank you very much! I really appreciate all your time and help with this tedder. Good luck with the new stirex
07-22-2013 17:00:16
 Re: Deutz Fahr KH40 Tedder in reply to AdamOH, 07-13-2013 04:58:05
I did some more digging and found a Fahr owners manual but it is for a KH400. I also found 4 or 5 pages for the KH40 showing the breakdown for the spinner heads and shafts (actually sent to me from another user on this site about 10 yrs ago!). Let me know if you'd like me to send them to you.
