rotary cutter
Anonymous-0
am doing some mowing with a John Deere 5303 tractor and a n MX7 JD cutter, having a hard time getting a clean cut across the whole width of the mower. Running in B-1 seems to work best but is painfully slow -this is a new mower- never had this issue with the old mod 306 bushhog mower - anyone else had this problem? It is level side to side and just a bit lower in the front. kj
Howe long since blades were sharpened? I just did mine on a Woods 7 foot Brush Bull and it made a huge difference. Even made a sound like a jet engine instead of a model A.
Oh. and taking out a 6-7 degree bend in the inner shaft helped a lot also. A little preventative maint before the thing went postal :)
Unless I overlooked something JD only offered suction type blades on a MX7. I agree check the blades for correct mounting. I also suggest marking slip clutch to be sure it isn't slipping.
