Yesterday's Tractor Co.
Shop Now View Cart
Using Your Tractor & Crop Talk
Discussion Board - Re: Grading old cow field
John A.
04-30-2013 06:52:59
Mr. Manouche, Having been in the High Plains where I have used a 50 ft land plane to get land flat enough to row water. I will add to LAA and showcrop comments. After you get the field worked up to the point is is loose, no big clods and all the weeds, grass, and the like is finely chopped up, Really mellow!
Get yourself a 20 ft stick of heavy R.R. iron. use it to drag out your field the result will be nice.
Or 3 spike tooth harrow sections hooked to a heavy 4 in or-so cross pipe. You can use something like a single R.R. tie to lay across each section for a little wt ant that will work right nice too. Hope this helps!
John A.
