Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: Cattle Feeding Area-Concrete? Asphalt?
randallinMo
02-21-2013 06:32:34
'Not saying that asphalt won't work, but I've NEVER seen it used in a livestock feeding area. Never. I'd definitely use concrete. I"d build a small "culvert" in the concrete down towards the bottom of the slope and then place a steel grate on the top to catch the runoff and divert it away from the barn.. You'll have to clean out the culvert periodically, but simply remove the top grate and shovel it out. No big deal. If you get a snow and ice build up, you can salt it or apply wood ashes for traction. I prefer the wood ashes if available. As for asphalt, by the time you get it laid down (via contractor), I doubt if you'll see any cost savings. 'Sounds like you've got a good base already, so not much required there, just pour on top of what you have now.
Formerly PaMike
02-21-2013 08:23:18
 Re: Cattle Feeding Area-Concrete? Asphalt? in reply to randallinMo, 02-21-2013 06:32:34
Will a skidsteer grip ok on concrete? I was thinking if you didnt trough it the concrete would be very rough and that would help....
randallinMo
02-22-2013 07:59:37
 Re: Cattle Feeding Area-Concrete? Asphalt? in reply to Formerly PaMike, 02-21-2013 08:23:18
If you leave the concrete "too rough" the skidsteer will grip too good....meaning it will eat your tires up. I know. Plus, too rough a surface is hard to scrape and it also eats up the bucket edge. You'll want to give the concrete a "broom" finish. It's easier for the cattle to walk on, it's easier to clean....just better all around.
caseyc
02-21-2013 12:19:21
It won't matter what your driving on, when there's snow/ice and manure, everything is gonna be slippery. Just no way around it. In the winter the manure and snow will freeze and it'll be rougher then a cob, unless you can keep it scrapped several times a day. Around here that's just not possible. I'd just be happy to have a solid surface in the spring when the frost is coming out!
Casey in SD
Copyright © 1997-2015 Yesterday's Tractor Co.
