| Using Your Tractor & Crop Talk |
Topic: Discussion Board - making a hay field
[Return to Forum]
| Author |
[Modern View]
| rick1
12-29-2012 06:07:26
70.194.2.74
about 2 years ago i planted a pasture mix for a hay field it contains a percentage of orchardgrass timothy alfalfa and 2 different clovers.i seeded it pretty heavy.i also fertilize it after each cut.it is rather thick and seems to take 4/5 days to dry.this year i am going to plant just orchard grass/timothy mix think that should dry a little quicker. RICK |
| JMS/.MN
12-30-2012 15:46:01
209.237.125.241
Re: making a hay field in reply to rick1, 12-29-2012 06:07:26
| Clover is extremely hard to dry. If using a conditioner, the rolls should be tight enough that you see the stems broken every couple inches....matching the conditioner roll. |
| rick1
12-30-2012 15:00:34
70.194.2.74
| i think i will try what donjr suggested doing.i have a rotary tedder that really does a nice job.i am considering getting a 7 or 8 ft. disc mower i think i could knock it down alot quicker sence i am pressed for time during the summer. RICK |
| donjr
12-30-2012 14:00:19
72.71.177.237
| Cut it and tedd it right after you finish cutting. Then tedd it again the next afternoon. Makes some beautiful hay... |
| rick1
12-29-2012 15:19:03
70.194.2.74
| sorry for confusing you i am going to keep this hayfield the way it is .i am making a couple more small fields maybe alfalfa/orchardgrass/tomothy but without the clovers.i mow with a ih 990 and also ted it. i also think i need to check the roll tension on the 990 i have a feelin it aint crimpin it a whole lot. RICK |
| tomstractorsandtoys1
12-30-2012 01:35:03
64.136.27.163
Re: making a hay field in reply to rick1, 12-29-2012 15:19:03
| I hate to say it but the 990 is part of the problem.They were great machines and dad had two seven ft. machines but when we started doing more alfalfa we had drying problems as well.We went to New Holland machines with the intermeshing rolls and it seemed to dry hay faster.For your few acres I would not go out and buy a different machine but would consider a few other things.You have a tedder,what type a bar type or a rotary? The rotary is much better as it moves the hay more. You could also buy a hay conditioner and run the hay thru after mowing.Run it thru right away or even the next morning, it will break up the stems more and pick the hay off the ground and move it allowing air to get under it better.When raking single windrows dry faster but take longer to bale.Even the tedder and conditioner are not perfect as both can cause leaf loss.It seems to me that we do not have as good of drying weather as we had 25 years ago,but then again our yeilds are much higher now.Not sure if I was any help just giving some ideas. Tom |
| rick1
12-30-2012 11:38:15
70.194.2.74
Re: making a hay field in reply to tomstractorsandtoys1, 12-30-2012 01:35:03
| i often questioned the 990 i would look at the roll contact between the 2 rolls and it seemed to look pretty good.then i would look at the hay after going thru the 990 and i couldnt tell by looking that it had went thru the rolls.i always assumed it would have sort of a flatter look to it after running thru the rolls. RICK |
| GordoSD
12-29-2012 07:35:30
216.106.244.233
| Where are you? Are you cutting it three times a season? Are you using a sickle mower. Are you conditioning the hay? Alfalfa/OG is some of the best hay there is. How old is the stand? With your fertilizing you should be good for many years. But you may want to sample as you could be gettin too much N in there. What was your yield per acre last year? Too many variables to give you and answer. |
| Larry NEIL
12-29-2012 07:45:21
75.63.61.26
Re: making a hay field in reply to GordoSD, 12-29-2012 07:35:30
| The grasses, timothy and orchard grass do dry faster than alfalfa and especially clover. It sounds like you have a good stand now. I would just throw 3-4 lbs of orchard grass seed in with fertilizer and spread it in the early spring. As Gordo said, if you want it to dry faster, need to cut with a conditioner and ted it out. That will take at least a day off of your drying time. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
