Yesterday's Tractor Co.
Shop Now View Cart
Using Your Tractor & Crop Talk
Discussion Board - Re: Spray Bar Height/Spacing
10-25-2012 19:37:55
20" spacings and 12 inches above the canopy. To achieve this you need a adjustable boom height.
You may get by with a set height if you can spray on time with no weather delays.
I have hydraulic boom height control and seems I adjust it for every field different than the one before.
When the wind blows it is nice to get it down as low as possible and still get good coverage.
Sprayer Setting Advice
10-26-2012 05:34:53
 Re: Spray Bar Height/Spacing in reply to IaGary, 10-25-2012 19:37:55
Thanks Gary. I'll do 20" spacing. This just has u-bolts holding the bar height, so I'll try setting it for the pre-emerge on beans and then try moving it up once for the corn and beans post-emerge being that the heights are similar. Hopefully I won't have to mess with it too much. I just farm 80 acres part-time, so I will be spraying when the weather is just right. If I have to do a second corn spray I'll hire it being that they'll knock over much less with their width.
10-28-2012 07:32:53
 Re: Spray Bar Height/Spacing in reply to Sprayer Setting Advice, 10-26-2012 05:34:53
get a chart to determine gallons per acre, it will have nozzle size, speed, spacing and pressure and will give you a gpa based on these factors, I use 8003 flat fan stainless tips which are pretty common.
