Yesterday's Tractor Co.
Shop Now View Cart
Using Your Tractor & Crop Talk
Discussion Board - Re: Not crop talk, but tractor work Feed grinders??
10-19-2012 09:41:31
I agree, the issue is wich will be cheaper to get it hauled/delivered or to mix it myself. Also the time cost. Can I mix a ton in the same 2 hours it would take to make the trip/purchase/load at the mill.
The feed for the breed stock isn"t much of an issue 1500 lb bag will last about 3 months.
10-22-2012 10:51:01
 Re: Not crop talk, but tractor work Feed grinders?? in reply to dmiller, 10-19-2012 09:41:31
Time wise, it won't take much more than 30 minutes to grind, mix and unload 2 tons of feed. This depends upon how you've got your grain set up....whether you have to shovel or not. Most mixers hold 2 tons. I'd grind 2 tons and leave part of it in the grinder if need be. Grinding feed really doesn't take long if you're using augers to move the grain to the grinder.
10-19-2012 10:45:50
I've had a couple Gehl mills and one Lorenz (MN product). Takes about 20 minutes to grind a two ton batch, depending how many ponies are up front.
