Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: No Till Lime
sdc eastern ia
10-08-2012 06:57:49
Before you make a decission look at the limestone from the quarry. If it is ground fine and a white color then use at 1.5 tpa. If the lime has a lot of pebbles then look elsewhere. Those pebbles will never breakdown in our lifetime. Maybe try pellime or so4. Where are you located?
sdc eastern ia
10-08-2012 07:07:11
 Re: No Till Lime in reply to sdc eastern ia, 10-08-2012 06:57:49
High mag lime is usually cheaper in my area. It will raise the ph but the magnesium attaches itself to the soil coloid lessening nutrient uptake. Callicetic (sp?) knocks off a hydrogen atom sweetening or raising the ph. Mag readings in our area are 170's to over 400.
randallinMo
10-08-2012 08:27:18
 Re: No Till Lime in reply to sdc eastern ia, 10-08-2012 07:07:11
sdc eastern ia......Sir, your statement that "magnesium attaches itself to the soil colloid lessening nutrient uptake"......is in error. Magnesium carbonate has a "greater" neutralizing value than calcim carbonate. In fact, one pound of magnesium carbonate will neutralize the same amount of acid as 1.2 pound of calcium carbonate. Soil tests that are low to medium in magnesium will recommend the use of high mag lime in order to meet the needs of the plant. Magnesium carbonate does NOT lessen nutrient uptake. It generally enhances it. Now, IF your soils are very high in magnesium to begin with, then you "might" create an imbalance that could possibly tie up certain nutrient uptake. Perhaps this is what you meant?
