Have a hay field (mostly grass, some alfalfa already sprayed with roundup about 4 days ago) that I want to plow out (chisel plow is what I have) and seed into winter wheat.
My question..
How will the ground moisture (if there is any) be effected by my plow timing? If I plow it all and then disc it (probably twice depending on how it breaks up coming out of sod) later do I want to disc soon after plowing or will it hurt it if it gets done a week later. Is this something that I should plan on doing the passes as close together as I can and get the seed in the ground or is it all right to do it spread out over a few saturdays?
My question..
