seedbed for winter wheat on irrigated ground.
dmiller
Went out yesterday to chisel plow the hay ground that will be planted to winter wheat. The plow is an old Graham Hoeme. The guy I worked for as a kid would have called it a field cultivator (not quite aggresive enough for a true chisel plow) but around here they call it a plow. Went in about 3 inches and plugged up every few yards with all the stubble/weeds.
So.... Should I disc the ground a few times to deal with the trash and then go back and chisel. Or should I hire a neighbor to mold board it for me? (don't own a true plow and can't afford one this fall).
Moisture would help but I'm not sure I can wait till the end of Sept/early Oct. I only get to farm weekends and evenings and not all of those. Not sure I could get the crop in fast enough if I wait too long into the fall. We often get snow the first week of Oct around here and then it's too wet to do much for a while.
Plowing with a moldboard would dry it out some unless your in an area that has decent moisture this year. Where are you from that you typically get snow that early?
i know 2 yrs ago farmer up the road fought plugged plow while plowing a field full of cornstalks and last yr disced same field and plow didnt plug up
