Yesterday's Tractor Co.
Shop Now View Cart
Using Your Tractor & Crop Talk
Discussion Board - Re: direction
08-08-2012 17:40:48
The only machine that cares about the direction is the baler and that is ONLY when you don"t rake the windrow. The windrow feeds into the baler smoother when going the same way as cut with a machine that puts it in a swath like a swather. If you rake it makes no difference the direction you bale after that. If you are using a big rake that pulls two windrows together then one swath will be against the cut. If you rake with single windrow rake then follow the way it"s cut if you can. The biggest thing to really watch out for is don"t rake or bale without some dew on or you lose the leaves. All this is in Alfalfa which is all I grow. Could be different for Grass.
