Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: Chisel plow vs Moldboard plow
JMS/.MN
08-05-2012 23:50:16
I run a 435 White 12 shank disc chisel behind my 4450 MFWD, (rated 145, cranks 190hp) generally 5 acres per hour, in heavy clay soil. A third faster than moldboard plowing with a 5-18. Bean ground, used to run a 12 shank Glencoe chisel (no discs) behind a 4430. Very little moldboard plowing here the last decade or two. Clay ground....worst job in the Fall here is better than the best you can do in the Spring. Much more mellow- whether moldboard or chisel. Before I had the 4WD 2470 Case or the current JD MFWD, I"d chain two 2wd together in the Fall if they could make it through the mud.
Copyright © 1997-2015 Yesterday's Tractor Co.
