Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Oats or barley
TnRoy
08-03-2012 06:01:45
I have been raising oats and some wheat,feeding the grain to my sheep and square baling the straw to sell. I was thinking about trying barley,here in east Tn barley costs $2.50 more per bu.than oats not that much money for the amount that I use, but which would make better feed and/or straw. Thank you for your comments or thoughts.
Walt(EIA)
08-03-2012 11:32:38
 Re: Oats or barley in reply to TnRoy, 08-03-2012 06:01:45
How about succotash? From the Welter Seed and Honey webpage:
Succotash is a mix of 1/3 early wheat, 1/3 barley and 1/3 medium maturing oats. For the livestock farmer this will give more pounds per acre than if each were planted separately. Succotash gives much more feed value to the acre than straight oats. It runs very high in protein. Many farmers like it for hog or calf feed.
TnRoy
08-03-2012 09:44:29
Thanks guys,Barley is what I was thinking too.As to Bobs question winter varietys work better for me,usually still too wet in the spring when it needs planting.Winter variety seems to be ready a little earlier,allowing more time for me to double crop with millet and blackhaybeans for hay cutting.
JMS/.MN
08-03-2012 08:55:26
Barley is 92% of the feed value of corn, much better than oats, and more adaptable to livestock in large amounts. Barley straw is less absorptive than oats straw.
Bob Bancroft
08-03-2012 08:48:08
I agree with LAA on barley being the better feed value. Here in NY we have the option with most small grains of planting "spring" or "winter" varieties. Typically one will do better than the other. Do you have anyone you could find out from, which would be better there- so you don't have to experiment?
LAA
08-03-2012 07:58:47
Oats @ 32 lbs. p/bushel and Barley @ 48 lbs. per bushel will usually yield about the same lbs. per acre, the Barley has more feed value and if you are fattening lambs you don't need anything but Alfalfa hay to go with the Barley. Barley straw is brighter than oat straw as a rule.
