| Using Your Tractor & Crop Talk |
Topic: Discussion Board - Re: Need Advice: I Have An Opportunity To Operate More
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| paul
07-29-2012 13:57:28
76.77.197.102
Us corn/bean farmers might have some ideas but not sure it relates so well to what you are doing.It sounds like you are mostly hay farming, with a little grain just to break up the rotation now and then? If you stay under 25 acres sounds like your equipment will work fine. Your 55hp tractor should pull 3-14 or 3-16 pretty good. If you get over 50 acres, I'd want a bigger pony, not just a turbo, but a bigger pony with a higher clearance tillage tool. Harvesting grain, I'd want a fella with a real combine in the wings I could call & be done with it if need be, harvesting can get _Real_ expensive when bad weather is coming and the old small stuff 'needs a little work'. --->Paul |
| Crazy Red Power in SE-WI
07-29-2012 23:07:03
68.114.237.14
Re: Need Advice: I Have An Opportunity To Operate More in reply to paul, 07-29-2012 13:57:28
| | Someone with a backup combine is a great idea. I'll have to start looking around & check out my options. Now that I think of it, a turbo is only an increase in power, not weight. Glad you got me to thinkin' about that. A bigger pony would certainly be something to save up for. Don't have the scratch for anything decent right now. I should have mentioned I'm on a very tight budget. What type of high clearance tillage tool would you reccommend? I'm not too savvy on contemporary tillage equipment. Yep, hay farming. About 15 acres will be in rotation. The rest will be semi-permanent pasture mix. The 400 with a 3-14 or 3-16 plow sounds like it might not be a bad idea. I'll have to find another Oliver. Mike
| jstalk
07-31-2012 05:26:05
70.60.1.22
Re: Need Advice: I Have An Opportunity To Operate More in reply to Crazy Red Power in SE-WI, 07-29-2012 23:07:03
| 400 will pull 4 14's , lose the chisel thought. get a 10' disc and harrow, and get a haybine of some sort, sickle bar and all the extra trips arent worth it, an H might be a 160 acre tractor but you'll be glad youre not doing that much believe me. |
07-31-2012 11:04:17
68.114.237.14
Re: Need Advice: I Have An Opportunity To Operate More in reply to jstalk, 07-31-2012 05:26:05
| | Yeah, I think I'll worry about a chisel plow when I get a bigger tractor. The disc I have, but a haybine is close to the top on the shopping list. I wouldn't turn down a second sickle mower & conditioner setup either. The ones like what I use are run in tandem. It IS more grease fittings, tires, etc. but I'm used to using this setup. When I move up to a windrower, it's going to have 14' of cutterbar, a cab & air, I assure you. :v) Probably a cab on the next tractor, too! Mike |
| paul
07-30-2012 07:46:06
66.44.133.112
| | In general, the newer a plow (or shisel plow, or field cultivator, etc) the farther apart the bottoms will be, the higher up the main beam will be. This allows morethrash (cornstalks, straw, etc) to pass through the machine without plugging up. Likewise, a 16 inch bottom plow will allow more trash to pass through than a 12 inch plow..... --->Paul |
07-30-2012 09:48:34
68.114.237.14
Re: Need Advice: I Have An Opportunity To Operate More in reply to paul, 07-30-2012 07:46:06
| | I've been looking at the plow (link below) for a while. It might be the right size for the 400, but I see what you mean by clearance under the beam. There isn't much there. Also, if four bottoms are too many for the soil at the horse farm, couldn't I just take the last bottom off? Or does it not work that way with those older plows? Mike |
| paul
07-30-2012 11:48:40
76.77.197.102
Re: Need Advice: I Have An Opportunity To Operate More in reply to Crazy Red Power in SE-WI, 07-30-2012 09:48:34
| | In my soil, an 85+ hp tractor got worn out fast pulling a 4-16 plow. I now run a 140hp tractor on a 4-18 plow, and that seems to be a good match. Obviously I have kinda tough soils. :) You need to be able to move the tailwheel up to be behind the 3rd bottom if you drop one off. Without looking too close or knowing much, it appears that would be possible? --->Paul |
07-31-2012 10:45:46
68.114.237.14
Re: Need Advice: I Have An Opportunity To Operate More in reply to paul, 07-30-2012 11:48:40
| | A-ha! I think I found one (link below), but I may have to act fast. The brochure I have on it says there's 21" fore & aft clearance & 27" from backbone to share. Plenty of room for 10" plowing. Sounds like just what I'm looking for. The one in the link below seems to have been dropped on it's tail wheel & I don't think a new lift rod is going to be easy to find. Mike |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
