Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Using Your Tractor & Crop Talk
Topic: Discussion Board - direction
[Return to Forum]
jaydee
07-26-2012 11:13:31
199.101.56.76
I have always understood that you should mow, rake and bale in the same directioin. Now what about after useing a haybine should the rake travel in the same direction, I just thought the way the hay flew through the rollers it wouldn"t matter much. What do you guys think?
[Reply]   [No Email]
dansuper27
08-08-2012 17:40:48
63.116.186.138
Re: direction in reply to jaydee, 07-26-2012 11:13:31
The only machine that cares about the direction is the baler and that is ONLY when you don"t rake the windrow. The windrow feeds into the baler smoother when going the same way as cut with a machine that puts it in a swath like a swather.
If you rake it makes no difference the direction you bale after that.
If you are using a big rake that pulls two windrows together then one swath will be against the cut.
If you rake with single windrow rake then follow the way it"s cut if you can.
The biggest thing to really watch out for is don"t rake or bale without some dew on or you lose the leaves.
All this is in Alfalfa which is all I grow. Could be different for Grass.
  [Reply]  [No Email]
Larry NEIL
07-30-2012 14:08:03
75.4.140.59
f you use a tedder, whats" the differance as the tedder tosses it in every direction anyway.
  [Reply]  [No Email]
jackinok
07-27-2012 07:18:23
162.58.82.136
I,my opinion,always did it the same. mostly because it was the easiest way to.pull in the gate drop your mower, of whatever kind.make one pass around outside ,turn around and keep cutting.simply was the way i always did it ,i dont know that it made a lot of difference.
  [Reply]  [No Email]
sid
07-26-2012 20:56:45
67.210.55.133
I do all three in the same direction. Things just seem to go smoother and those annoying little things that sometimes happen do not seem to happen as often.
I will not claim my hay is any better because of it but things sure do seem to go smoother because of it.
  [Reply]  [No Email]
jaydee
07-26-2012 20:30:29
199.101.56.76
OK thanks guys! I will rake however it"s convenient from now on.
  [Reply]  [No Email]
VicS
07-26-2012 19:36:14
70.195.2.147
When I was raking the other day, and it was 114, and the wind was blowing my windrows apart, I did think about it. I even made sure I raked some windrows the way they were mown. The hay was mown with a 8 ft drum mower and I was raking 3 of them together not touching the middle mower pass at all. My son is the baler, and he has never bragged on my raking ever! and he never bragged on the raking job when I went exactly the way it was mowed. lol Vic
  [Reply]  [No Email]
Brendon-KS
07-26-2012 16:31:07
63.245.190.37
Virtually all the farmers I've worked with using self-propelled windrowers always cut back and forth then rake two windrows together for their big balers. So, when raking, you're always rolling one of them against the way it was cut but I've never seen a situation where one windrow raked noticably cleaner than the other. Likewise, I've never seen a situation where the baler operator paid any attention to the direction the rake traveled. As others have said, the conditioner kind of ties the windrow together so it is probably different than if you were raking behind an old sicklebar mower.
  [Reply]  [No Email]
rrlund
07-26-2012 15:41:27
207.241.137.116
The only time it matters to me is if the hay is down so there's a lot of stubble laying down.
  [Reply]  [No Email]
IaGary
07-26-2012 13:29:12
108.160.229.48
Clear back to the sickel mower days of the 60's we doubled up the windrows. We would go in a circle skipping a rake pass on every round. When we got to the center we would turn around and throw the skipped pass into the windrow going the opposite direction.
Always did it this way with the mower conditioner as well.
Guess we were wrong for 50 years . But it worked fine without leaving any hay.
Maybe if the rake is junk it helps to go the same direction but we went any way with the rake, or baler for that matter, and never thought about.
  [Reply]  [No Email]
Old Iron
07-26-2012 12:01:29
24.225.2.188
I haven't seen any difference when putting up alfalfa with a haybine, V-rake, and big roundbaler.
In fact, I swath my hay going in one direction to the end of the field,... then turn around and cut the next swath going in the opposite direction.
I have a H&S High Capacity rack, and it's impossible to rake 2 windrows together in the same direction they were cut (the way I cut in a "back and forth" pattern).
Maybe if you were cutting hay with a sickle mower, the direction of raking and baling would make some difference in how things work,... but not with the equipment I use.
  [Reply]  [No Email]
KEH
07-26-2012 14:19:58
209.213.31.66
Re: direction in reply to Old Iron, 07-26-2012 12:01:29
I've never paid any attention to the direction of cut when raking, and I've used sickle bar mowers, mower conditioners, and disc mowers. I've used an old JD rake with the 2 wheels in front and swivel wheels behind, a NH 55, and now a Vermeer wheel rake. They all get the hay raked when in good condition and the cows don't turn it down when the hay is good.
KEH
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
