FactoryFarmer
Thought I'd share a few pictures form this spring. Kind of an odd spring for us, we were able to pretty much work all the through with only a few rain delays.
First picture is looking forward out over the hood and into the tabletop flat swap ground of NC IL. This land was not farmed until the 40's or so. The soil still contains fossils of the small snails and suck that used to live in the swamp.
The drainage ditches in the background were dug with a floating dredge and clay tile was laid to drain this ground. In all reality my family has struggled to farm it up until 1994 when the clay tile was finally done away with and new tile was placed every 90 feet.
This is where I spend alot of time in the spring. Day takes the day shift and then when he goes home to milk I take the night shift and we can keep the planting running for about 20 hours a day.
This display is the main brains on the entire setup. It steer the tractor, monitors the seed, and shuts off different sections of the planter in odd spots of the field to save seed. I work as a field tech for this company so that is why we use them instead of Deere's GreeStar, plus it is more accurate.
Over here from top to bottom we have: SmartBox for insecticide control, the original Kinze planter monitor as a backup, and the control box for the planter to fold it. The air gauge is to keep an eye on the air system that operates the seed clutches.
With this system we generally do not use markers.....
......except in very odd ares of the field such as here where I have a little finger to plant.
Last picture is nothing special, just a shot out the back. This land does best with moldboard plowing but as equipment advances someday we will no-till pretty much everything. Currently we have been no-tilling for around 12 years on other ground and it has been working good.
Feel free to ask any questions at all.
Thanks
Thanks
