Changing belts Mf 1135
Erik Ks farmer
Animal or anyone else have any experience changing the belts on a MF 1135? Replaced my ac compressor belt thinking that was where my belt squeal was coming from, but it is the belts running the alternator/fan/water pump. Haven't looked it up in the shop manual just yet but it doesn't look like fun.
It is not really that bad. Take the four bolts out of the drive on the crankshaft, slides back just enough to get the belts out. It is tight but its doable.
There are 4 depression holes in hyd pump that may need cleaned of dirt for drive plate bolts to enter, or plate and bolt ends will not give enough clearance to get belt past bolt ends.
