3020jd2955
I have been planting quite a bit of foxtail millet after baling all the small grain as a double crop before new small grain/hay seedings in the fall.
My question, can you plant millet into existing pure timothy stands and get a good crop of millet without damaging the timothy stand? I have a good bit of pure timothy and here in VA it is a one cut crop. Would really like to be able to get some use out of the timothy acreage later in the summer. But, I dont want to do something that will cause harm to the timothy stands.
The timothy fields are cut pretty short and always go dormant after cutting, so I would think the millet could get established with adequate moisture. Would something like this work?
Thanks for any advice.
