Grass control
Is atrazine labeled to use on raspberrys without injuring them.
I would think that atrazine would be hard on the berrys without knowing what the label says.
Even if you avoid direct contact with the plants, atrazine will leach through the soil to the roots.
Read the label.
Gary
Select, Select Max I beleive is labled for what you want. I know it is not exactly what you asked but I used Select Max last year on my alfalfa to control grass and as I remember the label had a huge variety of vegetable crops where select was used for grass control. The label is easy to look up on line.
