Grass in clover
4 bottem
Hi everyone What do you use to kill grasses in clover. Seeding clover on old corn ground. I know that the upside down grass will compete hard with the clover. Have atrazine and roundup. Have plowed and harrowed and of course picked rocks.
Don't use the ATZ, or you won't even get a stand of clover.
If the crop is planted and the grass and clover is emerged, I think Poast or Poast Plus have a label for grass control in clover. Rates are reduced during the seeding/establishment year. Requires the use of COC, and don't expect a quick kill of the grass, but it will die, try to spray it when the grasses are small for good control.
Same products as for clover and trefoil - see post below. I sprayed Select Max this spring, it worked real good.
