J.ReinkeFarms
I picked up another 50 acres to plant next year. The previous renter chisel plowed the soybean stubble, went broke, and gave up their rented ground. First thing I did was pull soil tests, I have never really worked with sandy ground before, but wow, the P and K levels are ok, calcium is way down and the pH average is 5.6 with a low of 5.1 and a high of 6.2. The field is unprotected from the wind so I don't want to spread lime in the winter. I was thinking about trying a band-aid fix and putting in 300lbs/acre of pellet lime mixed in and put in row with dry fertilizer and planting corn. Anybody else try this? Results? If it works out then this fall then I will spread 2tons/acre calacitic beet lime and chisel plow it in.
