Larry in GA.
I’m new to having to figure out good spraying practices. Growing up on the farm Dad all ways did the mixing and scheduling I was jest told go do.
Mudcat you mentioned spraying sweet corn 5 time in 7 days in the earlier post with what ever you are using. What kind of spry weight per acre are you talking about say using warrior and do you recommend keeping the mix rate the same for all the sprayings or tapering of as you go/ I guess I was thinking that using a wetting agent and spraying that much would cause a heavy build up.
And I guess that would be for Indian corn also??
Larry
Hobby Farming in South GA.
Larry
