Ed S.
- Location
- Middle Tennessee
[i:dd0b7afbfd](this is a repeat post from the Ford 8N board, so my apologies to anyone who already read it there)[/i:dd0b7afbfd]
While my hay felt pretty dry when we baled (rain predicted that evening), it apparently wasn't dry enough. We narrowly averted a barn fire (hay was starting to steam significantly) by restacking the bales outdoors two layers deep with plenty of air gaps inbetween the bales.
It's cooled down enough that we moved it back in the barn, and I'd say about 10-15% of the bales felt 'light' and looked like normal bales.
The rest, on the other hand, smells "bad," and looks carmelized inside (still putting off some heat in some bales). The outside flakes are okay in some cases, though. There's also some light molding (white) on about half the bales.
Our animals are older (11yo gelding quarter horse, three 2+yo nubian goat 'pets'), and they aren't picky about their feed.
The worst of the hay is going to go back in the field (will break apart and use the manure spreader), but would it be okay to feed out the rest? I'll be mixing in some good quality oat straw (which still has a good bit of grain in it) as noted in my other post.
What I'm interested in, is hearing your real-world experiences with marginal hay - feed it, or pitch it?
Thanks for sharing from your experience,
es
es
