Anyone got any manure they could spread on your plots? Do the lime & manure, forget the commercial fert for a year or 2. 10-10-10 would be a poor fert to order, if you established some good clover last year you already have 40+ lbs of N in the ground, you'll only need another 30-50 to make 100 bu corn. I can't see you going for 200bu the first year, you might only want to aim for 75bu yields? It's a food plot.... P & K it's hard for the crop to use more than 60 lbs of either if you are looking at 100bu corn. If you put on 500 lbs of 10-10-10 per acre (15 bags?) and if the lime was working already you'd get 100bu corn from the 50lbs of actual you were getting. I'd look for a better mix tho of fert. Starter here is 5-22-Iforgetbut 18 orso. 500 lbs of that per acre will break the bank this year, but give you a heck of a buildup of P&K for the next 3 years, and you can add a little N as you put a crop in. Fert dealers here deliver bulk, if you have some place to dump it in, wagon or such. Note that you will rust the heck out of anything of course.... You might need to have the whole 6 acres done this year, let them spread the lime & then spread the P&K. Those will help whatever you grow, & 6 acres might be enough to make it work for them. then you can add the N (which disappears much qucicker than P & K) as you want to yourself. Note that I put on more N, but less P&K than this for my corn fields, where I want 175+ yields & next year's bean P&K needs as well. You should not need tons of fert per acre! Lime I understand, but no way on the N-P-K! --->Paul
