Hi, I've got some leaking seals on my Case model 33 backhoe hydraulic cylinders. One stablizer and one swing cylinder has always leaked a little out the end. Now the boom cylinder is leading enough that sometimes it blows out the seal and leaks off when sitting. I can't chase that leak so its time to fix them. As far as I know, the piston packings hold and work just fine.
The boom cylinder has a 2 1/4" shaft and 5" cylinder. The stabilizer has a 1 3/4" shaft and a 4 5/8" cylinder. The pics should show where the seal is blown on the boom cylinder which I partially unscrewed. It has a flat rubber washer and 1/8" oring on the outside.
There is a pic of the stabilizer cylinder where I unscrewed the end collar. It has an 1/8" o-ring on the outside but no flat rubber washer like the boom cylinder. I can't see how to get at the seal and replace it. The pic of the stabilizer end collar shows a dime sized round place in the threads that apparently is filled with silicone.
Can anyone tell me how to get at the seals to replace them and how far do I need to tear them down to do it? Any parts online? Thanks for your help.
