Aaron Ford
Would a low float bowl level (due to a misadjusted float) cause an engine to run for 3 minutes perfectly then die? Or is this a symptom of a bad spark plug? If I wait a minute, it will start perfectly and run for three more minutes. I can keep it alive (sorta) with the choke, but the engine loads up badly. It will not run right until it has been shut down for a minute or so.
Been about everywhere on this generator and apparently I am not done yet. The magnet idea to contain the rust is working quite well.
Maybe I just need to change the fuel filter...
Back in a minute!
Aaron
Back in a minute!
Aaron
