Thought I had a distributor problem as I wasn't getting fire to the plugs & I had voltage to the distributor and no ground issues. The rotor does not spin at start attempt, will not spin by putting pressure on it either. Just before pullingthe distributor, I decided to pull the #1 plug and set piston at top center by feeling the blow. Problem is I don't feel anything blowing out, #4 is good. Where do I start tinkering to figure out if this is one problem with the crankcase/cam & their gears or multiple problems with them and the pistons/valves? Or something else? Help greatly appreciated!!!!!
