1958 Int. 340 Utility. With Conomatic Pippon LoaderBack Hoe
Anonymous-0
Help! I just replaced 1 Hyd. Cyl. on the Back Hoe. I know I collected 2 gallons of fluid doing so. When I went to add new fluid, I removed the level plug and fluid poured out. So, is there another location to add hyd. fluid? What am I missing? Besides a manual!!
I have different unit so this might not apply to you:
rebuilt hydraulic cylinder is probably full of air, after you hook up the hoses and cycle it a few times the oil level in the tank should go down a lot
