4230 john deere
Anonymous-0
I have a 4230 john deere.The small long shaft that runs through the tractor under the cab broke.After lifting the cab and removing the cover i replaced the shaft and reassembled the tractor.Now my 3 point doesn't work.Is it possible that the cam follower was in the wrong position or could there be some other issues? I wasn't sure what position it was in when i removed the cover.Thats the only thing i can think of.
Yes you probably missed getting cam in correct place. IIRC you could pull rockshaft valve control housing instead of complete RS housing to reline cam.
