5ft Box Blade vs. 6 ft Box blade.
Anonymous-0
Hey guys
I am looking at buying a box blade for my new tractor (Ford 860) for repairing a driveway and landscaping my 5 acres. My dilemma lies in the size of box blade to get. I know I want a blade with ripper teeth, and I have located several good deals on 5 ft blades. But would I be better off with a 6 ft blade since my tractors rear-end (tire edge to tire edge) is 5 and ½ ft wide, which wood make the 6ft blade wider then the rear end. Would this make for easer use, or am I looking to in to this?
Thanks
James Jones
James:
I use a HD 6' box blade with my 860, which has heavy pie weights but no liquid ballast.
I use it mostly for moving crushed rock but have also used it for backfilling excavation projects and minor landscaping projects.
Dean
I rented a 5' blade to pull behind my MF35 since that was what I could rent. It worked fine, but if I was going to buy one I would think a 6' would be handier since it would mean fewer passes.
Zach
My son's box blade has a tag that says, "Max HP 40". He has a 30 HP tractor.
Don't know the horsepower of your tractor, but I'd surely want one that was rated to handle the tractor horsepower.
I also agree that the six foot blade would be nicer for cleaning out your tire tracks - unless it's more than your tractor can handle.
Paul
6 feet is the ideal width box scraper for the 861. Anything smaller and you'll regret your purchase every time you use it.
