old
- Location
- Camdenton Missouri
Well after pulling off one panel of siding I found which way the wire went. I then pulled off some under pinning and laid down under it( not what I call fun) and saw a place in the wire that has a burned area in it. Hope that is the only bad spot. Bad thing is I also found where the kitchen drain pipe has been knocked down by the insulation I had put in in May of 2007 by a contractor poor work man-ship. So now what was one problem is 3 oh well such is life. If I can I will put that wire in some pipe at least in the area of the splice it will have in it.
Thanks guys for your ideas they did help
