TractorLinks.com
Tractor Talk Discussion Forum
alternator for International 284 diesel 1984
Kerry Starin
04-21-2010 09:30:30
I have a 1984 International 284 diesel that needs a alternator repaired or replaced. I can not find a alternator or parts. Does anybody out there know if a alternator or parts are available. How about a conversion kit or differant alternator that would work. Thanks Kerry Starin, Poynette WI.
Owen Aaland
04-21-2010 19:15:48
 Re: alternator for International 284 diesel 1984 in reply to Kerry Starin, 04-21-2010 09:30:30
I came up with it being an Hitachi alternator. IH part number 1058309C91, replaced by 1430430R91. List price of the new replacement is only $623.29. Better buy two so you have a spare!
The Hitachi model number is LT 120-8. Rated 12V, 20 amps, at 5000 RPM, external regulator, external fan. Neither of the vendors I normally use for parts listed anything for an Hitachi alternator that small.
Your best bet may be to try to find an alternator off a car or pickup that fits your brackets. The pulley can be changed to match what you need on the tractor. Many alternators can be rotated to get the wires in the right location.
It is doubtful that you will be able to find one that has as low an output as the one from your tractor but a larger unit should still work. If the amperage output is a lot greater you can add another wire from the battery to the alternator to carry the load if the original wire is too small. If you find a replacement that has an internal regulator a few wiring changed should make it usable.
Let us know what you come up with.
kerry starin
05-01-2010 10:04:16
 Re: alternator for International 284 diesel 1984 in reply to Owen Aaland, 04-21-2010 19:15:48
I found a small automotive repair shop in Madison, WI. that repaired the broken parts inside the old alternator. They had to repair the rectifier. I do not know of any shops that do that kind of repair any more. They charge me $175.00 to overhaul my alternator. It works great. The name of the shop is FONDY AUTO REPAIR.
Allan In NE
04-21-2010 09:53:20
Heck,
I'd go to the parts house and get a alt to fit an '84 Mazda car. That's what the engine is.
Allan
Allan In NE
04-21-2010 09:54:38
 Re: alternator for International 284 diesel 1984 in reply to Allan In NE, 04-21-2010 09:53:20
Whoops!
Didn't see the "diesel" part. Still bet it would work tho. :>)
Allan
