I have been planning to build a pole barn approximately 24x 36 and was wanting to put tubing in the floor for heating down the road. However I have been told that in order to do this the right way I would either need to put in frost footings and insulate in between the footing wall and the slab, or bury 2" foam vertical in place of the footing wall to keep the frost from coming under the slab. I understand that I would need to put foam under the slab to insulate it, and foam around the perimeter for insulation also. I guess I don't understand the frost issue 100%. Has anyone done this in a colder (North NE) area and how did you do it and how did it work? thanks for any ideas and help in advance.
