How big can you bore a 350?
I have a farmall H that needs more hp. I also have a 350 that I am willing to go BIG with. Need to know how big and what pistons I can go with. It looks like I can use M pistons and modify the rods to work with no sleeves. Can I go that big or bigger? Any advice will be helpful.
Thanks
As O.P. says .080 has been achieved BUT!... you really need a 4 core radiator as heat becomes a major factor. A good cam, head set-up, and carb will make all the difference in the world. Stay away from edlebrock carbs, they are junk on just about any set-up. I've seen a properly jetted quadrajet out perform a edle hands down. And when/if, you put headers on, use the longest ones possible.... a long header = torque.
I rather get the impression that we might be talking about two different 350's....the Original Posted likely meant the International 350, as this is a tractor forum, where as I get the feeling you guys might be leaning more towards a 350CID 'street' engine.
Am I right?
Matt, seems like B&D and I are the only ones that "get" what you are doing. Maybe posting on the pulling board is the better idea, Us guys over there do that stuff all the time. mEl
