Anonymous-0
13.6 x 28 rim - valve stem area on rim repaired nicely built up with 7018, ground and shaped, just need to know what the valve stem hole diameter should be.
Easy repair, metal not too thin from the CACL valve stem leak, built er up in no time, 90-100 amps on the heat, 1st few passes, then 110 amps for the last passes, good penentration and no porosity at all.
