Walt Davies
Did you ever notice that your tractor and equipment can set nicely in the garage and never give you any trouble, then take out to do some work and they all blowup at the same time.
1. PTO on Kubota ( $450 in parts )
2. water pump on Case 485 O ( $124 in parts )
3. power steering on Cockshutt ( easy fix return line needed to cut off and put back on )
4. PTO shaft cover on MacDon mower turns hot and melts the catches grass The my partner catches the Hyd. In the PTO shaft tears out 2 ft. of it.
Make one want to just quit farming doesn't it.
Walt
PS anybody want a cheap farm?
Walt
