Tractor Talk Discussion Forum
belarus 825 pto
ddhuntsd
12-06-2007 18:19:39
i have a 825 belarus tractor that worked great with my gyro mower this summer. when i put my snow blower on it barely gets the snow out of the spout. oil levels are good. is there an adjustment or clutches to adjust for the pto? also, on the k-5 koyker loader i can"t find a lever to allow the loader to "float". any advice? thanks. doug
Trkr
12-07-2007 09:20:54
 Re: belarus 825 pto in reply to ddhuntsd, 12-06-2007 18:19:39
Before you adjust those screws you should make sure the pto lever is centered.On the right side or the rear housing where the pto linkage arm goes into the housing it has a tapped hole that you put a bolt thru and screws into the housing and holds the lever centered while you adjust the screws.
Trkr
12-07-2007 09:24:03
 Re: belarus 825 pto in reply to Trkr, 12-07-2007 09:20:54
Do you have a seperate valve for the loader or are you using the built in russian valve?If you using the russian valves shove the lever all the way forward to float.
nhboyd
12-07-2007 00:54:29
The pto can be adjusted. Look for a small cover on the top of diff case it under 3pt cyl. remove cover. 5 bolts You will see what looks like screw driver blade. There will be two one is for brake the other is clutch. turn one clockwise half turn at a time. should have good pull on lever to get snap to engaged possion.
