Tractor Talk Discussion Forum
A6 354 Perkins Diesel engine
Dan-IA
09-15-2006 16:59:03
Hi, I was wondering if there are any tractors used domestically that use this particular engine. Looking for a winter project, and we've got a few of these engines laying around (spares because we buy massey combines for parts) and it'd be nice to have a tractor that uses this engine. Seems at 120HP, it'd be a pretty good sized tractor. I just think that if some old tractor used this, then maybe if I look around I can find a matching tractor chassis that can be had from a salvage yard for a reasonable price, and we can breathe life back into it...
Thanks!
ejr-IA.
09-16-2006 10:44:05
 Re: A6 354 Perkins Diesel engine in reply to Dan-IA, 09-15-2006 16:59:03
The White 105 ,2-85 use them.Brother inlaw and I used a 750 354 in his 105.
Kevin (FL)
09-16-2006 07:47:28
Dan,
We could use a 6-354 (for our shrimp boat) the turbo version (about 160 HP). I could rebuild it down here. Only problem is that funds are low due to Ivan, Dennis & Katrina expenses.
A good weekend to all.
RustyFarmall
09-16-2006 07:23:37
What are the possibilities of doing a transplant into an older pick-up truck or maybe into an older non-diesel tractor?
Jack in Fla
09-16-2006 15:23:54
 Re: A6 354 Perkins Diesel engine in reply to RustyFarmall, 09-16-2006 07:23:37
I have a 1976 F-250 Ford that I put a 6-354 in, with a 5 speed clark trans, and 3spd aux.It worked good and was going to rebuild it, and I bought a new 1000 series perkins and replaced it. It is 200 hp turbocharged and aftercooled, (air to air), It does good and gets about 14 mpg when I am not pulling 27ft gooseneck.Have had this motor in for about 6 years now. you can go to Case38man photos, and look for tractor haulers if you would to see it Jack
barnrat
09-16-2006 05:03:57
Most 90 to 125hp Massey tractors(too many to list)built between 1964 and 1992 had the Perkins 354. There are 3 different series during that period but I have had little trouble adapting between series and tractor.
Drill
09-15-2006 18:55:52
A lot of Massey Ferguson's use that engine. 1100, 1105, 1130, 1135, 2705,All are good tractors. Also some White tractors 2-105, and some others I don't know the numbers.
Some MF combines also had that engine, going back to the 510, then the 750 and some others. It is a real popular engine used in construction equipment and even some marine applications.
jim1650
09-15-2006 17:04:43
1850 olivers use that engine
