Tractor Talk Discussion Forum
Farm Equipment On Public Roads - Michigan
sammy the RED
05-23-2006 08:15:22
# 9486 - MICHIGAN: TODAY'S FARM EQUIPMENT ON PUBLIC ROADS
State Laws That Apply to Farm Machinery on the Public Roadway
A Few Definitions
"Vehicle - every device in, upon, or by which any person or property is or may be transported or drawn upon a highway,..." [MCL 257.79]
"Farm Tractor - is every motor vehicle designed and used primarily as a farm implement for drawing plows, mowing machines, and other implements of husbandry". [MCL257.16]
"Implement of Husbandry- means a vehicle which is either a farm tractor, a vehicle designed to be drawn by a farm tractor or an animal, a vehicle which directly harvests farm products, or a vehicle which directly applies fertilizer, spray or seeds to a farm field". [MCL 257.21]
General
A Driver's license - not required for operating an implement of husbandry.[MCL 257.302. [211]]
A License Plate - not required on any implement of husbandry (refer to definition). [MCL 257.216c]
Self-propelled farm implements - must not be operated on freeways or limited access highways. [MCL 257.679a]
Crawler or track- type tractors - must not be operated on roads unless owner has a special permit from State Highway Commissioner, county road commission or other authority having jurisdiction. [MCL 257.725 [3]]
Impeding Traffic - A person, without authority, shall not block, obstruct, or otherwise impede the normal flow of vehicular or pedestrian traffic by means of a barricade, object, or device or with his or her person. [MCL 257.676b]
Comment: Vehicles including implements husbandry, are not allowed to be parked on the main traveled portion of the highway. Highway includes a paved or unpaved roadway.
Lighting And Warning Equipment
Lights must be used from a half hour after sunset to a half hour before sunrise, or when visibility is reduced to less than 500 ft. [MCL 257.684]
Minimum lighting is at least one white light visible for a distance of 500 ft. in front and at least one red light visible for a distance of 300 ft. to the rear. [MCL 257.695] However, traveling less than 20 mph, your vehicle may use reduced lighting requirements. [MCL 257.703]
When lights are required, implements of husbandry shall have a rear red light or be accompanied by an escort vehicle which follows behind at a distance of not more than 50 ft. and illuminates the implement of husbandry with the escort vehicle's headlights and displays on the rear of the escort vehicle lighted rear lamps as required by law. [MCL 257.686 [411]]
A farm tractor maybe equipped with flashing amber light in addition to the 4-way flashers which may be used after dark and when visibility is poor. [MCL 257.698 [5][e]]
When operated on the highway, a Slow Moving Vehicle (SMV) emblem is required for;
* every vehicle which has a maximum potential speed of 25 miles an hour, * an implement of husbandry, * farm tractor, or * special mobile equipment. [MCL 257.688g]
An equilateral triangle must be mounted on the rear of the vehicle, broad base down, not less than 3 ft. nor more than 5 ft.above the ground and as near the center of the vehicle as possible. In addition, red reflectors or reflectorized tape is required on rear at each side of equipment. [MCL 257.688g]
Size, Weight and Loads
Comment. Traveling "left of center" after dark or during poor visibility is never permitted. Impeding the flow of traffic, at any time, is a violation.
The provisions governing size, weight, and load shall not apply to implements of husbandry incidentally moved upon a highway. [MCL 257.716 [2]]
A person may operate or move an implement of husbandry of any width on a highway as required for normal farming operations, so as to minimize the interruption of traffic flow. However, a person must not operate or move an implement of husbandry to the left of the center of the roadway:- from a half hour after sunset to a half hour before sunrise; when approaching the crest of a grade or upon a curve when the driver's view is obstructed within a distance as to create a hazard in the event a vehicle might approach from the opposite direction; when the view is obstructed upon approaching within 100 ft. of a bridge, viaduct, or tunnel; or at any time visibility is substantially diminished due to weather conditions. [MCL 257.717 [2] & 257.639 [1]]
A truck-tractor (semi) shall not haul more than one trailer and one semitrailer or more than two semitrailers in combination at any one time, except that a farm tractor may haul two wagons or trailers. The total combination of farm tractor and two wagons cannot exceed 55 ft. in length, and m ust not travel at a speed in excess of 15 miles per hour. [MCL 257.719 [3]]
However, a vehicle (car, truck, or pickup truck) shall not haul more than one farm wagon or trailer. [MCL 257.721 [1]]
A person operating a vehicle to transport agricultural commodities in the normal operation of a farm is not required to cover the load. [MCL 257.720]
A person operating a vehicle to transport agricultural commodities in the normal operation of the farm shall not spill. [MCL 257,720]
However, it is not considered spilling when a vehicle transporting agricultural or horticultural products including hay, straw, silage, or residue from the product, escapes from the vehicle in an amount that does not interfere with other traffic on the highway.[ MCL 257.720[l]]
Did You Know ???
* That "driving and drinking" laws apply to implements of husbandry. [MCL 257.625] * That anhydrous ammonia tanks or other vehicles carrying hazardous materials on which a placard is required shall stop at all railroad crossings. [MCL 257.669] * That when pulling a farm wagon or trailer with a vehicle (such as a truck or farm tractor) safety chains are required. [MCL 257.721] * That a person riding an animal on the roadway shall have all of the rights and responsibilities as the operator of other vehicles. [MCL 257.604] * That SMV emblems cannot be used to mark driveways, mailbox or any other stationary object within the highway right-of-way. [MCL 257.688] * That no white light may be displayed to the rear of an implement of husbandry, [MCL 257.689] nor white lights to the front that blind on-coming traffic. [MCL 257.700 and 257.696] * That any time an implement of husbandry or farm tractor is operated on the roadway, a SMV emblem must be displayed and clearly visible on the rear of the implement. [MCL 257.688 [g]] * That your SMV emblem must be clean and highly reflective. [MCL 257.691 [g]]. Most experts agree that SMV's become faded within 2-5 years and should be replaced.
This information has been prepared in cooperation with:
THUMB AREA TRAFFIC SAFETY COMMITTEE
MICHIGAN RURAL SAFETY COUNCIL
MICHIGAN STATE POLICE
Motor Carrier Division
Traffic Services Unit
MICHIGAN STATE UNIVERSITY
Agricultural Engineering Department
MICHIGAN FARM BUREAU
Public Affairs Division
HURON COUNTY HEALTH DEPARTMENT
Farming Safely in the Thumb Program
OFFICE OF HIGHWAY SAFETY PLANNING
For more information contact any of the above.
hayray
05-24-2006 05:44:56
 Re: Farm Equipment On Public Roads - Michigan in reply to sammy the RED, 05-23-2006 08:15:22
Sammy,
thanks for posting that, I am going to print that off and keep it in my tractors so next time the dip ---- pig that pulls me over I will shove it in his face. So I guess I have to put safety chains on everything, any specs on how those have to be mounted? So do this mean I can pull wide loads at night so as long as I don't cross the center line on a curve or hill?
Ray
Marty Johns
05-23-2006 18:58:22
Safety FIRST !!!!! !! But it seems that alot of those laws, contradict themselves, read them carefully and you'll see what I mean!!!!! !!
Mike M
05-23-2006 11:17:12
Take all that and throw it out in the trash if your AMISH. I bet they are exempt.
After reading all those laws and setting up the equipment who has time left to do any farming ? These law writers are getting out of hand way, way too many !
hayray
05-24-2006 05:40:22
 Re: Farm Equipment On Public Roads - Michigan in reply to Mike M, 05-23-2006 11:17:12
No, the Amish all have SMV signs on all their vehicles and they have amber lights on the rear and heads on the front -- pay attention next time.
Ray
Mike M
05-24-2006 07:43:20
 Re: Farm Equipment On Public Roads - Michigan in reply to hayray, 05-24-2006 05:40:22
You all must have the high class ones around you !!!!! !!!!!
John S-B
05-23-2006 17:45:23
How long does it take to put on an SMV, what 5-10 minutes at most? Most modern equipment is already set up to comply with current laws. In Ohio the Amish all have SMV's on their buggies and wagons. They all have lanterns for night time. If you're a farmer sounds like your main crop is sour grapes, lighten up. The laws posted above are about as common sense as it gets.
Mike M
05-24-2006 04:31:01
 Re: Farm Equipment On Public Roads - Michigan in reply to John S-B, 05-23-2006 17:45:23
I'm in Ohio and ALL THE AMISH DO NOT HAVE SAFTEY DEVICES. The ones that do use laterns are darn hard to see,just about useless in fog. Many around me use nothing in the daytime either.They get away with alot more than you and I.
Not alot of common sense in all that legaleze ! Is everyone to have a lawyer with them at all times ? Seems that's what the world is coming to.
LE Smith
05-23-2006 09:55:03
I know all the laws are supposed to be for the good of the people, sometimes it is necessary to reinforce common sense. I too make every effort to comply as we do a lot of road travel in our west central part of MI. There have been a couple of very serious accidents in the area over the past few years that most likely could have been less serious or avoided all together if the equipment had been properly set up with SMV signs, tape, lights, etc. As a member of the Newaygo County Farm Bureau I support all efforts to make transport of farm equipment safe for both the farmer and general public. I have to bite my tounge however when I see neighbors not even using a SMV sign as a minimum. It is even worse when they do not seem care they are putting themselves, their family or the public at risk for an accident by not following basic safety measures when roading equipment. I am proud of the fact we stress safety on the farm and on the road, and our teenagers who also move equipment down the road, take safety seriously and with out the harping of Dad, make sure all SMV signs are in place and all lights are in working order before setting out. We can be our own worst enemy if we leave safety up to the politicans by letting them dictate to us how to be safe on the roads we all use by our own carelessness and "I don't care" attitudes.
Dave H (MI)
05-23-2006 08:33:37
Slow day down thar in Jackson County, eh my friend (lol)? I found this interesting reading and am in compliance but for the reflectorized tape. Guess I will have to figure out where to get some and then how to make it stick to an old hay rack. One thing I did not see is how many implements I can tow behind a farm tractor. Currently my standard ops is to hook the baler with three wagons behind it and the rake trailing the end. Too much??? Usually have someone driving behind to keep the maniacs from hitting me. Hey, since you are having a slow day why don't yah stick a SMV on the back of the old plow and drop er off in my front yard? Don't ferget the red tape!
sammy the RED
05-23-2006 21:13:36
 Re: Farm Equipment On Public Roads - Michigan in reply to Dave H (MI), 05-23-2006 08:33:37
Please look at MCL 257.719 [3] above, you will find your answer there. ;o]
I have a trailer that can haul that IHC #70 4-16.
And ..... .... It won't fall off !
