Tractor Talk Discussion Forum
3010 clutch problem
Dean in iowa
04-13-2006 19:15:27
Have a 3010 gas. After the tractor warms up you can not get it in gear unless you idle it all the way down. a new front disc was installed by the dealer. The old one showed very light warpage. the rest of the clutch looked very good. Put in a new disc and still the same problem. Any sugesions?
msb
04-13-2006 20:56:31
 Re: 3010 clutch problem in reply to Dean in iowa, 04-13-2006 19:15:27
Probably one of two things.The pilot bearing needs replaced of the clutch fingers are not adjusted correctly.Its an outsideshot,but the springs might need to be replaced.I would guess someone is not good at adjusting the finger height.It can be tricky sometimes if you don't really watch to place the finger height tool correctly.
the tractor vet
04-13-2006 20:53:09
Sounds like that they may have pulled the tractore together and warped the disc .If they don't sorta slide together while wiggelen and turning the engine over by hand this can happen .
