Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
IXL oil treatment
F.E. Bear
01-20-2003 06:59:16
Has any one on the site ever heard of IXL oil treatment or ever used it. I saw a guy here at the N. Ft. Myers FL. flea market running an old Chrysler slant six with out the rocker cover and oil pan. The only lube it had was the residual oil and treatment left in the engine. It is pricy and sounds almost too good to be true. But he claims it works. It requires only 2 oz./ quart initially and 1 oz. after that. Almost every thing that sounds too good to be true--IS. I could not see on the brochure where or who makes it, (red flag?) only the name of the distributer. I'm curious-----. Fred
TimC
01-21-2003 06:59:08
 Re: IXL oil treatment in reply to F.E. Bear, 01-20-2003 06:59:16
Everyone has to decide for themselves but the only problem is most people make the assumptions without testing the products in their own shop. It is easy to jump on the band wagon and discredit a product without any knowledge of what these are for. As for the product you are talking about, it does sound like a gimic using the running motor without oilpan and rocker cover. It makes a good show. Did they tell you what the base ingrediants are???
Regular motor oil is good enough to make an engine last a long time. That being said, there are products that will make them last longer, wear less, run cooler, reduce friction and create a few more horse power and or better fuel milage.
To find out the facts you can search out a product called Militec-1 which looks to be a good product. You can do a patent search for 5,885,942
and read the ingrediants.
You can read about Oil Extreme one of the most convincing articles at http://www.oilextreme.com/index.html scroll down to the motor tech mag article. Very convincing.
I am not endorsing either of these products because i use something else and have proven it to work. I believe in it enough to sell it myself
and only sell it to friends here at home. They always act supprised when their fuel milage goes up. I use it on drill bits, string trimmers, lawn mowers, any type bearings that are getting hot.
The most important advice you can get is to test some of these products out for yourself.
Tom
01-20-2003 20:39:10
He probably also sells snake oil which will cure cancer. I have some land in Florida I will sell you.
Don LC
01-20-2003 07:11:56
We have very good oils today....no need to add anything to your oil....you would be wasteing your money......
Copyright © 1997-2015 Yesterday's Tractor Co.
