!!!!!!!!!!!!!!!!6V OR 12V!!!!!!!!!!!!!!!!!!!!!!
stephen e key
02-07-2002 11:41:56
I have just bought a david brown cropmaster (1950) and i dont know if it is 6v or 12v PLEASE HELP
Stephen(aged 15)
old timer
02-08-2002 06:59:00
 Re: !!!!!!!!!!!!!!!!6V OR 12V!!!!!!!!!!!!!!!!!!!!!! in reply to stephen e key, 02-07-2002 11:41:56
Steve check out the earlier posts earlier on this page regarding David Brown tractors, I am going to guess that it would most likely be a 6 volt,also you will need to know if it is positive ground or negative ground. good luck.
Glenn(WV)
02-07-2002 15:22:44
Unless someone has performed a conversion, dollars to doughnuts it's got 6v electricals.
Salmoneye
02-07-2002 13:32:39
If the old battery is still in it, count the caps...3=6 volt...6=12 volt...
RAB
02-07-2002 12:03:33
Look on starter motor. Almost certainly stamped on this somewhere. Look at light bulbs. -almost certainly stamped/printed on these somewhere. Try 6 volts across a bulb - if is bright it is a 6 volt. Try 12v - no don't,if its a six volt as it will probably blow it!!
Have fun, have a look.
Regards, RAB
butch in kansass
02-08-2002 17:59:41
 Re: Re: !!!!!!!!!!!!!!!!6V OR 12V!!!!!!!!!!!!!!!!!!!!!! in reply to RAB, 02-07-2002 12:03:33
1955 an on 12 volt before 6 v pos grd most 12 v neg gerd few execpetin in big trucks
