FARMALL H NO SPARK
Courtland
01-31-1999 17:21:28
1946-H Tractor sat for 9 mos. For some reason no spark. Also looking for wiring diagram to confirm correct connections. Thank you..
John T
02-01-1999 07:20:21
 Re: FARMALL H NO SPARK in reply to Courtland, 01-31-1999 17:21:28
Its usually the ignition points are corroded. Clean and check gap and give it another try. Condensors can also go bad but if its not one of those, post or e mail back for more info. John T
Curt Cooke
01-31-1999 19:00:10
Mag or Dist., chances are your points are at fault, greened over by moisture. Remove and replace or thoroughly clean.
43 H
01-31-1999 19:19:07
 Re: Re: FARMALL H NO SPARK in reply to Curt Cooke, 01-31-1999 19:00:10
Check all of your connections. Espesially the at the mag. I had a problem similar with my 340. The brass/copper ends of the wires and points corrode quickly and need to be checked periodiclly and cleaned also. If that doesn't help take of the coil and have it checked.
Good Luck
