What is this? Ford 540 Industrial
thirdrock
Found no reference of it in owners or service manual.
From what I can see it looks like an aftermarket heater. Does it have connections for heater hoses? The tractor may have had something for a cab or enclosure on it at one time and someone added a heater for winter use.
The back of the housing is solid sheet metal. It has one 12v or signal
wire running out of it thats disconnected & theres two hoses. Heres
photos of where theyre running to.
The cab at a minimum had a windshield previously because I see a
wiper mechanism. The tractor does have a loader.
X2 looks like a heater to me. At one time probably had a
switch with a couple resistor to give the fan 2-3 speeds.
The last 2 pics are hot water connections, so probably go to heater box. Had some kind of weather protection on it , Maybe soft cab.
its a fresh air machine.break wind its blown away.
heat houser with a heater.even on a cold day that turned on might feel good open station or not
