This will help float the river barges
Doug Wi
we had about 18 of heavy wet snow when the temps hit 70 + degrees. Most went in 3 days. we are about 15 miles east of the st. croix river which feeds into the mississipi. further north near the
headwaters of the st croix, they had 3' of snow in the woods. Ans its all headed south. Many culverts washed out or close to it. Township was running out of road closed signs. This is tractor related because I drove my 8n down to the creek to take the pictures. Third picture is a 5A hay field Washout is much bigger now. Took the pictures about 3:30. Checked about 8:30 this evening and the blacktop id gone all across the road . Shouldn't be any trouble moving full barges once this gets down river. 3:30.
These computers do everything possble to confuse me. Had this all set and then the 1st pic doubled up. So did it again and now the 4th pic is the hayfield. Guess I could make bigger mistakes then this.
Did you by chance go to preview what you typed & went back to change something before submitting your reply? Sometimes when you do that, a pic or two will double post. Then you have to go back & delete whichever line is doubled. Should be ok then.
Mike
I think we should be treating some of this water & put it back underground so we can water crops later when they need it.
